Device: Vero
Installation media: SDcard
Connection: Wired
Power Supply Type: AS supplied with Vero
Power specs:
Peripherals:
Storage Device: SMB
OSMC version: 2015.07-1
Audio/Video Output: HDMI
Logs: http://paste.osmc.io/beduxikuru
After doing the latest update anything that I play (web stream, video, mp3) the audio is running at almost half speed. (Like someone slows down a record) If it is something with video the picture seems to be running at normal speed without any problem. I have been searching everywhere and can not find anywhere that points me where I may be able to fix this issue.
Thanks for any help
David
Is the audio slow in video playback as well ?
What resolution and refresh rate are you set to in system settings ?
Can you redo your log file please - it’s complete empty.
@DBMandrake Yes it is slow with video also. I uploaded a small mp3 file to the SD card also to make sure it wasn’t a network issue and it still has the same half speed.
Video output - 1920x1080p
Audio output - imx-hdmi-soc
The other audio options I have tried different settings and it doesn’t seem to make a difference. # Channels 3, Output config Optimized (tried all 3)
http://paste.osmc.io/ivafateneg
Thanks,
David E.
Your refresh rate seems to have defaulted to 59Hz. Please try manually adjusting it to 60Hz in settings and that should fix the sound issue.
Cc @mk01 @sam_nazarko
Thank you, that got it. I was focused on the Audio settings page and didn’t even pay attention to the video page (not that I would have noticed or know that it was set wrong)
Thanks again,
David E.
Glad that sorted it! It is a bug with the Audio sample rate being incorrect when the HDMI refresh rate is set to 59Hz.
