Hey,
I’ve been having this problem for a few months now. The audio randomly gets “muted”/skips for ~1-2 seconds (it is still in sync after that) while playing video files. Going back like 10 seconds and watching the same scene again, it is back to normal. This can happen once every 6 or every 30 minutes, with FLAC, AC3, DTS, different file types/containers/codecs, so I don’t see a pattern there, though here are 3 examples that were pretty bad iirc.
example no.1
General
Unique ID : 243367550972695565641615137216630221339 (0xB716E2A8FCE4810EB5954AC104E1EA1B)
Format : Matroska
Format version : Version 2
File size : 8.03 GiB
Duration : 1 h 35 min
Overall bit rate : 12.1 Mb/s
Movie name : The House of the Devil (2009)
Encoded date : UTC 2013-08-29 22:20:00
Writing application : mkvmerge v6.3.0 (‘You can’t stop me!’) built on Jun 27 2013 22:06:07
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 10.2 Mb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.460
Stream size : 6.76 GiB (84%)
Title : The House of the Devil (2009)
Writing library : x264 core 135 r2345 f0c1c53
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=tesa / subme=11 / psy=1 / psy_rd=1.19:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=9 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=17.9 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.66
Language : English
Default : Yes
Forced : No
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 509 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 1.00 GiB (12%)
Title : Main
Language : English
Default : Yes
Forced : No
Audio #2
Format : Vorbis
Format settings, Floor : 1
Codec ID : A_VORBIS
Bit rate mode : Variable
Bit rate : 80.0 kb/s
Channel(s) : 2 channels
Stream size : 54.5 MiB (1%)
Title : Commentary
Writing library : Lancer 20110424 (UTC 2011-04-24)
Language : English
Default : No
Forced : No
Audio #3
Format : Vorbis
Codec ID : A_VORBIS
Title : Commentary
Language : English
Default : No
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English
Language : English
Default : No
Forced : No
[details=example no.2]General
Unique ID : 214843367382517569383045904791354333449 (0xA1A153D462BA0C8FBA69B4A57365D909)
Format : Matroska
Format version : Version 4 / Version 2
File size : 4.41 GiB
Duration : 1h 31mn
Overall bit rate : 6 897 Kbps
Encoded date : UTC 2016-10-21 19:07:08
Writing application : mkvmerge v9.0.1 (‘Obstacles’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
DURATION : 01:31:30.422000000
NUMBER_OF_FRAMES : 514727
NUMBER_OF_BYTES : 1035630724
_STATISTICS_WRITING_APP : mkvmerge v9.0.1 (‘Obstacles’) 64bit
_STATISTICS_WRITING_DATE_UTC : 2016-10-21 19:07:08
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : AVC
Format settings, ReFrames : 5 frames
Duration : 1h 31mn
Bit rate : 5 251 Kbps
Width : 1 920 pixels
Height : 808 pixels
Display aspect ratio : 2.40:1
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.141
Stream size : 3.36 GiB (76%)
Writing library : x264 core 148 r2705 3f5ed56
Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 1h 31mn
Bit rate : 1 509 Kbps
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 988 MiB (22%)
Language : German
Default : Yes
Forced : No[/details]
[details=example no.3]Video
Format : AVC
Duration : 1h 41mn
Bit rate : 4 455 Kbps
Width : 1 916 pixels
Height : 796 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.122
Stream size : 3.16 GiB (90%)
Title : T
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 41mn
Bit rate : 384 Kbps
Frame rate : 31.250 fps (1536 spf)
Stream size : 279 MiB (8%)
Title :
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:1
00:02:57.000 : en:2
00:07:11.000 : en:3
00:12:10.000 : en:4
00:17:20.000 : en:5
00:21:41.000 : en:6
00:25:57.000 : en:7
00:32:10.000 : en:8
00:36:58.000 : en:9
00:42:34.000 : en:10
00:47:49.000 : en:11
00:50:48.000 : en:12
00:56:49.000 : en:13
01:02:55.000 : en:14
01:08:29.000 : en:15
01:12:41.000 : en:16
01:20:01.000 : en:17
01:24:23.000 : en:18
01:28:45.000 : en:19
01:32:47.000 : en:20
[/details]
Files are sitting on different external HDDs hooked up to different USB ports. Some have an external power source some are powered by the Vero 2 device.
Issue happens whether the sound goes to my AV receiver or is directly put out via HDMI --> TV speakers.
This happens randomly like I said so I am not able to… idk turn on debug logging and reproduce the error.
Plus my Vero2 got pretty buggy too in the last few months. When doing tasks like quickly skipping through the library or removing something from the library because the files aren’t there anymore it’ll often freeze and then do the “big sad face crash and reboot”. I played around with different kodi skins, most of them not running smoothly, and am now back to the original osmc design. Don’t know if that could have caused problems.
I realize I have not uploaded a log. I want to ask a developer/team member something before I do, so if you are reading this and are online to help comment and I’ll PM you. Thanks.
If this makes more sense please feel free to move this post to the “Vero2” forum.
But tbh I always assumed that it was a big “reset everything to default” kind of button.
