I have what seems like a sync Issue with the latest August 2021 update.
When Kodi is running, even when just sitting there on the menu, I can see an Audio sync issue.
Checking my AV Receiver, I see a constant drop of the AV happening.
That is, I see the LEDs for showing me what connection is currently on the AV side going off and on in a cycle.
First I though I had some bad cable or something, but switching to another HDMI port on the TV or using an App on the TV does not show this issue.
It is also noticeable once you play a Video file that Audio is dropping every few seconds.
I did some testing, and it seems to only happening on 4K UHD resolution, 3840x2160p.
If I switch to Full HD 1920x1080p Audio sync is fine, and no drops happening.
Setup is a Samsung TV with a breakout box with SPDIF to the AV Receiver.
Any help on how to narrow it down is much appreciated.
