I’m experiencing some issues with audio sync when watching “Jet Lag: the Game” on Nebula using the slyguy Nebula addon on my Vero 4K+.
I previously opened an issue with the addon developer, but after some investigation we have determined that the issue is not with the addon, and is likely with OSMC and/or the Vero 4K+.
Expected behaviour:
- Install the slyguy Nebula addon
- Using the addon, sign in to Nebula
- Navigate to a Jet Lag video
- Play the video
- Audio should be in sync with the video
Actual behaviour:
- Audio is several seconds ahead of the video
Episode 2 of the Japan season (the latest episode as of the time of submission of this issue) is a good example. It begins with an extended motion-graphics sequence, and the sound effects that play in time with the graphics on desktop play several seconds ahead on Kodi.
Adjusting the audio offset in Kodi makes no difference: the audio plays several seconds ahead of the video, regardless of how the audio offset is set.
So far it appears to only be Jet Lag that is affected. None of the other creators that I watch have the same issue, including the other channels by the same creator (Wendover Productions, Half as Interesting).
The same video plays with the correct audio offset in a web browser, and the YouTube version of Jet Lag plays with the correct audio offset in Kodi.
Previous seasons were not affected by this issue when I watched them at the time of release, but I also tested some previous episodes today and found the same issue.
I’ve tested this with three versions of the addon (0.2.3, 0.2.4, and the latest 0.2.5) and get the same behaviour in each case. I’m running the latest available version of OSMC.
I’ve also tested this on Kodi on my Ubuntu desktop, and the addon developer has tested on his Windows machine, and in neither case can we reproduce the issue. It’s only on my OSMC Vero 4K+ that I’ve been able to reproduce the issue.
Here is a log extract from playing a video:
2023-06-07 16:40:26.171 T:3153 warning <general>: Setting most video properties through ListItem.setInfo() is deprecated and might be removed in future Kodi versions. Please use the respective setter in InfoTagVideo.
2023-06-07 16:40:26.222 T:2952 info <general>: VideoPlayer::OpenFile: plugin://slyguy.nebula/?_=play&_play=1&slug=jetlag-ep-2-we-played-a-96hour-game-of-capture-the-flag-across-japan
2023-06-07 16:40:26.230 T:3300 info <general>: Creating InputStream
2023-06-07 16:40:26.394 T:3300 info <general>: AddOnLog: inputstream.adaptive: [Repr. chooser] Resolution set: 1920x1080, max allowed: 1920x1080, Adjust refresh rate: 0
2023-06-07 16:40:26.584 T:3300 info <general>: AddOnLog: inputstream.adaptive: Successfully parsed manifest file (Periods: 1, Streams in first period: 3, Type: live)
2023-06-07 16:40:26.584 T:3300 info <general>: Creating Demuxer
2023-06-07 16:40:26.587 T:3300 info <general>: Opening stream: 1001 source: 256
2023-06-07 16:40:26.687 T:3300 info <general>: Creating video codec with codec id: 27
2023-06-07 16:40:26.688 T:3300 info <general>: CDVDVideoCodecAmlogic: using Amlogic decoder H.264/MVC
2023-06-07 16:40:26.722 T:3300 info <general>: secureOSMC setup successful
2023-06-07 16:40:26.723 T:3300 info <general>: auth_get_key_id: TEEC_InvokeCommand failed with code 0xffff0006 origin 0x4
2023-06-07 16:40:26.723 T:3300 warning <general>: OSMCSecureOS::getKeyId: unable to get key id
2023-06-07 16:40:26.723 T:3300 warning <general>: OSMCSecureOS: key-id = <unknown>
2023-06-07 16:40:26.726 T:3300 info <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2023-06-07 16:40:26.726 T:3300 info <general>: Creating video thread
2023-06-07 16:40:26.727 T:3300 info <general>: Opening stream: 1002 source: 256
2023-06-07 16:40:26.729 T:3306 info <general>: running thread: video_thread
2023-06-07 16:40:26.835 T:3300 info <general>: Finding audio codec for: 86018
2023-06-07 16:40:26.842 T:3300 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2023-06-07 16:40:26.842 T:3300 info <general>: OpenStream: Allowing max Out-Of-Sync Value of 10 ms
2023-06-07 16:40:26.842 T:3300 info <general>: Creating audio thread
2023-06-07 16:40:26.842 T:3300 info <general>: Opening stream: 1003 source: 256
2023-06-07 16:40:26.845 T:3310 info <general>: running thread: CVideoPlayerAudio::Process()
2023-06-07 16:40:26.882 T:3300 info <general>: CDVDSubtitlesLibass: Using libass version 1500000
2023-06-07 16:40:26.882 T:3300 info <general>: CDVDSubtitlesLibass: Creating ASS library structure
2023-06-07 16:40:26.882 T:3300 info <general>: CDVDSubtitlesLibass: Initializing ASS Renderer
2023-06-07 16:40:26.884 T:3300 info <general>: CDVDSubtitlesLibass: Initializing ASS library font settings
2023-06-07 16:40:26.962 T:3300 info <general>: CDVDSubtitlesLibass: Creating new ASS track
2023-06-07 16:40:27.326 T:3306 info <general>: CBitstreamConverter::Open bitstream to annexb init
2023-06-07 16:40:27.346 T:3310 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2023-06-07 16:40:27.347 T:3310 info <general>: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2023-06-07 16:40:27.357 T:3047 info <general>: CActiveAESink::OpenSink - initialize sink
2023-06-07 16:40:27.357 T:3047 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-06-07 16:40:27.358 T:3047 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-06-07 16:40:27.358 T:3047 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-06-07 16:40:27.367 T:3047 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-06-07 16:40:27.367 T:3047 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-06-07 16:40:27.367 T:3047 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-06-07 16:40:27.369 T:3047 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-06-07 16:40:27.388 T:3047 error <general>: CAESinkALSA - snd_pcm_writei(-32) Broken pipe - trying to recover
2023-06-07 16:40:27.887 T:2952 info <general>: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
2023-06-07 16:40:27.897 T:2952 info <general>: Constructing CRendererAML
2023-06-07 16:40:29.142 T:2952 info <general>: CVideoPlayer::CloseFile()
2023-06-07 16:40:29.142 T:2952 info <general>: VideoPlayer: waiting for threads to exit
2023-06-07 16:40:29.143 T:3300 info <general>: CVideoPlayer::OnExit()
2023-06-07 16:40:29.143 T:3300 info <general>: Closing stream player 1
2023-06-07 16:40:29.145 T:3300 info <general>: Waiting for audio thread to exit
2023-06-07 16:40:29.150 T:3310 info <general>: thread end: CVideoPlayerAudio::OnExit()
2023-06-07 16:40:29.151 T:3300 info <general>: Closing audio device
2023-06-07 16:40:29.171 T:3047 info <general>: CActiveAESink::OpenSink - initialize sink
2023-06-07 16:40:29.171 T:3300 info <general>: Deleting audio codec
2023-06-07 16:40:29.172 T:3300 info <general>: Closing stream player 2
2023-06-07 16:40:29.173 T:3300 info <general>: waiting for video thread to exit
2023-06-07 16:40:29.185 T:3306 info <general>: thread end: video_thread
2023-06-07 16:40:29.187 T:3300 info <general>: deleting video codec
2023-06-07 16:40:29.192 T:3300 info <general>: Closing stream player 3
2023-06-07 16:40:29.207 T:3069 info <general>: Deleting settings information for files plugin://slyguy.nebula/?_=play&_play=1&slug=jetlag-ep-2-we-played-a-96hour-game-of-capture-the-flag-across-japan
2023-06-07 16:40:29.214 T:3300 info <general>: ADDON: Dll Destroyed - InputStream Adaptive
2023-06-07 16:40:29.216 T:2952 info <general>: VideoPlayer: finished waiting
2023-06-07 16:40:29.216 T:2952 info <general>: CVideoPlayer::CloseFile()
2023-06-07 16:40:29.216 T:2952 info <general>: VideoPlayer: waiting for threads to exit
2023-06-07 16:40:29.273 T:2952 error <general>: Control 55 in window 10025 has been asked to focus, but it can't
2023-06-07 16:40:29.369 T:3047 info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2023-06-07 16:40:29.369 T:3047 info <general>: CAESinkALSA::Initialize - set digital codec 0
2023-06-07 16:40:29.370 T:3047 info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2023-06-07 16:40:29.376 T:3047 info <general>: CAESinkALSA::Initialize - Opened device "default"
2023-06-07 16:40:29.377 T:3047 info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2023-06-07 16:40:29.377 T:3047 info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2023-06-07 16:40:29.386 T:3047 info <general>: CAESinkALSA::Initialize - speaker layout 0
2023-06-07 16:40:30.047 T:3153 warning <general>: Setting most video properties through ListItem.setInfo() is deprecated and might be removed in future Kodi versions. Please use the respective setter in InfoTagVideo.
The addon developer suggested that the issue might be related to the message “Your hardware does not support AE_FMT_FLOAT, trying other formats”, and linked to the following issue from a different project that appears to be similar: RPi4 (Bullseye update) Kodi error: "Your hardware does not support AE_FMT_FLOAT" · Issue #4998 · MichaIng/DietPi · GitHub
Please let me know if there’s anything I can do about this issue, or if there’s anything I can do to help you investigate it further. Thanks!
