I’ve had the same issues for some time now. Looking forward to an update!
@sam_nazarko - hi Sam can you confirm that this patch was reverted please?
The patch has been reverted in Kodi Jarvis builds, which will be made default soon when the stable version is released.
@sam_nazarko hi Sam, has this been reverted?
Yes – this has been reverted for some time.
Hi Sam
I have noticed he same audio sync issue on my Vero 2 when playing mkv video.
The above linked patch changes AESinkAUDIOTrack - how is that in any way related to linux? It’s the Android Audio sink.
Yes. You are right…
This post was for the Vero (original). If you make a new post in the Vero 2 section I can help you
@sam_nazarko I have only just managed to test this out. Unfortunately I still have a sync issue across all my media. I have to set a delay of 1.075 ms, I may have to tweak this value.
Any ideas? The time this manifested itself was when you put the patch in. I know you said you reverted it but it doesn’t seem to have made any difference. I did not experience this issue prior to that patch.
There is little more annoying in life than lip sync issues. It detracts from the enjoyment of watching a film as you are constantly analysing if the sound is in sync. A 1st world problem but a problem nonetheless.
As fritsch pointed out, the patch makes no difference, so it wouldn’t cause problems, in or out, for iMX6.
If the audio is consistently out of sync, you could apply this offset for all videos. Has anything changed in your AV setup (AVR, TV, surround not enabled before, etc).
I’m confused, why would there be a patch for Android done back in oct/Nov last year?
Anyway, the only difference in my setup is that i am currently not using any AV equipment so not using pass through just using the TV sound.
However, when the problem started I was using AV equipment and it started after the release I mention above so either the patch caused it or something else in that release.
I’m not in a position at the moment to use the AV equipment to do a direct apples to apples comparison.
However if the patch isn’t the cause then it shouldn’t really matter as the reverting of the patch wouldn’t have fixed my issue, right?
I dropped it in after seeing it in another tree but never tested to see if it made a significant difference myself. We can consider it placebo
Okay, that may explain the difference, and why we didn’t have many reports around the same time.
That’s correct. Builds with the patch and without should behave identically in terms of audio delay, or at least, this patch won’t be making the difference.
If you are always using TV sound (downmix?), and the offset is always the same,consider setting it as the Default for all videos.
That’s my point Sam. The delay was there when using AV equipment and when not. It appeared after the release I mentioned above. It is only recently that I have been using the TV sound. During all my chasing in this thread asking for the patch to be removed I was using AV equipment. It has only been since the end of Feb that I have been using the TV sound.
I’m still unsure if the delay effects all media in the same way. I had a much better experience prior to the release because I never had to touch the delay, it just worked.
Can you:
- give me a MediaInfo output of a file you are playing that has the delay?
- paste-log /home/osmc/.kodi/userdata/guisettings.xml
@sam_nazarko the paste-log is here: http://paste.osmc.io/efaboviwid
The MediaInfo is:
General
Unique ID : 232331710579562388504193513273200465327 (0xAEC975B84F37282BA227306A95CFD5AF)
Complete name : \Osmc\e841-fa58\torrents\complete\Star.Wars.Episode.VII.The.Force.Awakens.2015.1080p.BluRay.x264.DTS-HD.MA.7.1-RARBG\Star.Wars.Episode.VII.The.Force.Awakens.2015.1080p.BluRay.x264.DTS-HD.MA.7.1-RARBG.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 14.5 GiB
Duration : 2h 18mn
Overall bit rate : 15.0 Mbps
Movie name : RARBG.COM - Star.Wars.Episode.VII.The.Force.Awakens.2015.1080p.BluRay.x264.DTS-HD.MA.7.1-RARBG
Encoded date : UTC 2016-03-23 03:23:27
Writing application : mkvmerge v8.9.0 (‘Father Daughter’) 64bit
Writing library : libebml v1.3.3 + libmatroska v1.4.4
Cover : Yes
Attachments : cover_land.jpg / small_cover.jpg / small_cover_land.jpg / cover.jpg
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 18mn
Nominal bit rate : 9 825 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.267
Title : Star.Wars.Episode.VII.The.Force.Awakens.2015.1080p.BluRay.x264.DTS-HD.MA.7.1-RARBG
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=24 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=9825 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 2h 18mn
Bit rate mode : Variable / Constant
Bit rate : Unknown / 1 509 Kbps
Channel(s) : 8 channels / 6 channels
Channel positions : Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 93.750 fps (512 spf)
Bit depth : 24 bits
Compression mode : Lossless / Lossy
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : English-SRT
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Title : English-SDH-SRT
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Title : English-PGS
Language : English
Default : No
Forced : No
Text #4
Format : PGS
Muxing mode : zlib
Title : French-PGS
Language : French
Default : No
Forced : No
Text #5
Format : PGS
Muxing mode : zlib
Title : Spanish-PGS
Language : Spanish
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:00:09.259 : en:00:00:09.259
00:01:43.061 : en:00:01:43.061
00:03:51.857 : en:00:03:51.857
00:06:12.289 : en:00:06:12.289
00:09:33.948 : en:00:09:33.948
00:10:43.560 : en:00:10:43.560
00:12:35.713 : en:00:12:35.713
00:13:39.694 : en:00:13:39.694
00:14:48.221 : en:00:14:48.221
00:16:45.922 : en:00:16:45.922
00:18:04.583 : en:00:18:04.583
00:19:21.535 : en:00:19:21.535
00:21:26.619 : en:00:21:26.619
00:24:03.651 : en:00:24:03.651
00:26:47.022 : en:00:26:47.022
00:29:54.668 : en:00:29:54.668
00:31:49.324 : en:00:31:49.324
00:35:51.775 : en:00:35:51.775
00:36:40.615 : en:00:36:40.615
00:37:45.513 : en:00:37:45.513
00:40:19.250 : en:00:40:19.250
00:43:39.200 : en:00:43:39.200
00:45:29.560 : en:00:45:29.560
00:49:22.918 : en:00:49:22.918
00:51:19.952 : en:00:51:19.952
00:54:13.750 : en:00:54:13.750
00:59:48.794 : en:00:59:48.794
01:04:16.061 : en:01:04:16.061
01:08:37.238 : en:01:08:37.238
01:11:07.221 : en:01:11:07.221
01:15:16.387 : en:01:15:16.387
01:16:49.897 : en:01:16:49.897
01:19:37.523 : en:01:19:37.523
01:20:56.894 : en:01:20:56.894
01:25:36.173 : en:01:25:36.173
01:32:12.569 : en:01:32:12.569
01:35:29.015 : en:01:35:29.015
01:36:34.956 : en:01:36:34.956
01:39:28.629 : en:01:39:28.629
01:41:29.959 : en:01:41:29.959
01:42:57.505 : en:01:42:57.505
01:45:00.002 : en:01:45:00.002
01:50:33.710 : en:01:50:33.710
01:53:39.771 : en:01:53:39.771
01:55:22.165 : en:01:55:22.165
01:58:05.453 : en:01:58:05.453
02:01:05.592 : en:02:01:05.592
02:02:32.679 : en:02:02:32.679
02:07:07.578 : en:02:07:07.578
Thanks.
@sam_nazarko Hi Sam - did you manage to take a look at this?
Yes. Did you update?
We have done what we can for environments without AVRs that incur post processing
Thanks Sam I will update later today and report back my findings.
@sam_nazarko Hi Sam, since the update I can’t select hdmi as the output in the audio section. It’s greyed out and only shows spdif as the selection! So now I have no sound from my Vero. Can you please take a look at this as a matter of urgency?
I am sure that if this was the case for other users we would have received reports of it. I think that dumping your EDID would be useful here. For now you can downgrade your kernel:
sudo apt-get install --reinstall vero-image-4.4.0-1-osmc
