Perhaps I should create a new topic since I got same message but for a 1080p video.
I have just received the vero 4k+ and all is perfect except the big lebowski where english audio uses Dolby digital plus. The avr is a x3500h from denon, all passthrough.
I may provide log, need to check wiki and forum since Linux is quite new (argh these windows guys).
So issue is that audio and video are stuttering, if I switch to dts french it’s fine.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
You can also create the mediainfo-output of the affected media file on the OSMC device:
login via SSH, user osmc, password osmc
if not already installed: sudo apt-get update && sudo apt-get install mediainfo
cdto the directory containing the video/audio material in question
since mediainfoonly needs to read the header information of the file data, copy the first 4 Mbytes of the media file to a new file: dd if="<media file>" of=purgeme.bin bs=1024 count=4096
upload the decoded media information using mediainfo purgeme.bin|paste-log
publish the returned URL here in this topic
remove the created media file snippet rm purgeme.bin
I don’t see any specific data when I paste the link… anyway I launched the movie in French (OK), after a few seconds I switched to English, FPS decreased to 23 fps on screen.
