Hi all, I recently purchased an August DVB-T210 to get UK Freeview channels through OSMC on my Pi 2b as it was my understanding that this device was supported from kernel 3.16. I installed Tvheadend from the app store and the device showed up as Silicon Labs Si2168 : DVB-T #0. However when I went to scan the muxs all the scans failed. running dmesg appeared to show that the required firmware files were missing so I downloaded the files dvb-demod-si2168-b40-01.fw & dvb-tuner-si2158-a20-01.fw from dvb-firmware/firmware at master · OpenELEC/dvb-firmware · GitHub and placed them in /lib/firmware however the device still does not scan the muxs
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.2.1-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Wed Sep 23 17:57:49 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B Rev 1.1
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80a48440, node_mem_map ae156000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9460->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 12 pages/cpu @ae118000 s19328 r8192 d21632 u49152
[ 0.000000] pcpu-alloc: s19328 r8192 d21632 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=960 bcm2708_fb.fbheight=576 bcm2709.boardrev=0xa01041 bcm2709.serial=0xf0057f97 smsc95xx.macaddr=B8:27:EB:05:7F:97 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 742668K/770048K available (7748K kernel code, 550K rwdata, 1820K rodata, 412K init, 762K bss, 19188K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80960324 (9569 kB)
.init : 0x80961000 - 0x809c8000 ( 412 kB)
.data : 0x809c8000 - 0x80a51aec ( 551 kB)
.bss : 0x80a54000 - 0x80b12a4c ( 763 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000012] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000034] Switching to timer-based delay loop, resolution 52ns
[ 0.000312] Console: colour dummy device 80x30
[ 0.000534] console [tty0] enabled
[ 0.000560] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000590] pid_max: default: 32768 minimum: 301
[ 0.000985] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001008] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002256] Initializing cgroup subsys blkio
[ 0.002296] Initializing cgroup subsys memory
[ 0.002337] Initializing cgroup subsys devices
[ 0.002362] Initializing cgroup subsys freezer
[ 0.002404] Initializing cgroup subsys net_cls
[ 0.002477] CPU: Testing write buffer coherency: ok
[ 0.002560] ftrace: allocating 19043 entries in 56 pages
[ 0.049017] CPU0: update cpu_capacity 1024
[ 0.049058] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.049075] [bcm2709_smp_prepare_cpus] enter
[ 0.049211] Setting up static identity map for 0x8240 - 0x8298
[ 0.078912] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.079279] [bcm2709_secondary_init] enter cpu:1
[ 0.079334] CPU1: update cpu_capacity 1024
[ 0.079343] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.088889] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.089161] [bcm2709_secondary_init] enter cpu:2
[ 0.089191] CPU2: update cpu_capacity 1024
[ 0.089199] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.098894] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.099147] [bcm2709_secondary_init] enter cpu:3
[ 0.099176] CPU3: update cpu_capacity 1024
[ 0.099184] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.099276] Brought up 4 CPUs
[ 0.099307] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.099318] CPU: All CPU(s) started in SVC mode.
[ 0.100307] devtmpfs: initialized
[ 0.122895] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.123427] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.124517] pinctrl core: initialized pinctrl subsystem
[ 0.125307] NET: Registered protocol family 16
[ 0.130745] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.158712] cpuidle: using governor ladder
[ 0.188744] cpuidle: using governor menu
[ 0.188877] bcm2709.uart_clock = 3000000
[ 0.195557] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.195576] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.195768] Serial: AMBA PL011 UART driver
[ 0.196062] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 0.196768] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.270457] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 0.270511] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 0.271601] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 0.271619] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 0.272211] SCSI subsystem initialized
[ 0.272451] usbcore: registered new interface driver usbfs
[ 0.272562] usbcore: registered new interface driver hub
[ 0.272725] usbcore: registered new device driver usb
[ 0.273472] raspberrypi-firmware soc:firmware: Attached to firmware from 2015-09-23 12:21
[ 0.300584] clocksource: Switched to clocksource arch_sys_counter
[ 0.351465] FS-Cache: Loaded
[ 0.351915] CacheFiles: Loaded
[ 0.368477] NET: Registered protocol family 2
[ 0.369688] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.369830] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.370023] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.370148] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.370214] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.370656] NET: Registered protocol family 1
[ 0.371215] RPC: Registered named UNIX socket transport module.
[ 0.371234] RPC: Registered udp transport module.
[ 0.371245] RPC: Registered tcp transport module.
[ 0.371256] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.371804] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.374416] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.374630] audit: initializing netlink subsys (disabled)
[ 0.374695] audit: type=2000 audit(0.349:1): initialized
[ 0.389972] VFS: Disk quotas dquot_6.6.0
[ 0.390354] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.393246] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.394383] NFS: Registering the id_resolver key type
[ 0.394450] Key type id_resolver registered
[ 0.394462] Key type id_legacy registered
[ 0.397334] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.397525] io scheduler noop registered
[ 0.398086] io scheduler bfq registered (default)
[ 0.398098] BFQ I/O-scheduler version: v7r7
[ 0.400552] BCM2708FB: allocated DMA memory eec00000
[ 0.400665] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.411091] Console: switching to colour frame buffer device 120x36
[ 0.418444] vc-cma: Videocore CMA driver
[ 0.418461] vc-cma: vc_cma_base = 0x00000000
[ 0.418473] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.418484] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.418775] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.436611] brd: module loaded
[ 0.446363] loop: module loaded
[ 0.447460] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.449183] Loading iSCSI transport class v2.0-870.
[ 0.450087] usbcore: registered new interface driver smsc95xx
[ 0.450156] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.650508] Core Release: 2.80a
[ 0.650533] Setting default values for core params
[ 0.650593] Finished setting default values for core params
[ 0.851010] Using Buffer DMA mode
[ 0.851025] Periodic Transfer Interrupt Enhancement - disabled
[ 0.851036] Multiprocessor Interrupt Enhancement - disabled
[ 0.851047] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.851064] Dedicated Tx FIFOs mode
[ 0.851506] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 0.851546] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 0.851571] dwc_otg: Microframe scheduler enabled
[ 0.851642] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8054c124
[ 0.851663] WARN::hcd_init_fiq:413: FIQ ASM at 0x8054c494 length 36
[ 0.851683] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf89a000
[ 0.851735] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.851785] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.851838] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 0.851892] Init: Port Power? op_state=1
[ 0.851903] Init: Power Port (0)
[ 0.852230] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.852252] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.852268] usb usb1: Product: DWC OTG Controller
[ 0.852284] usb usb1: Manufacturer: Linux 4.2.1-1-osmc dwc_otg_hcd
[ 0.852299] usb usb1: SerialNumber: 3f980000.usb
[ 0.853440] hub 1-0:1.0: USB hub found
[ 0.853507] hub 1-0:1.0: 1 port detected
[ 0.854340] dwc_otg: FIQ enabled
[ 0.854355] dwc_otg: NAK holdoff enabled
[ 0.854365] dwc_otg: FIQ split-transaction FSM enabled
[ 0.854405] Module dwc_common_port init
[ 0.854745] usbcore: registered new interface driver usb-storage
[ 0.855116] mousedev: PS/2 mouse device common for all mice
[ 0.855686] usbcore: registered new interface driver usbtouchscreen
[ 0.856168] bcm2835-cpufreq: min=600000 max=900000
[ 0.859298] sdhci: Secure Digital Host Controller Interface driver
[ 0.859307] sdhci: Copyright(c) Pierre Ossman
[ 0.859621] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 0.859633] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[ 0.890678] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.891162] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.891298] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.891466] usbcore: registered new interface driver usbhid
[ 0.891475] usbhid: USB HID core driver
[ 0.891735] Initializing XFRM netlink socket
[ 0.891764] NET: Registered protocol family 17
[ 0.891902] Key type dns_resolver registered
[ 0.892025] Registering SWP/SWPB emulation handler
[ 0.900137] registered taskstats version 1
[ 0.900321] vc-sm: Videocore shared memory driver
[ 0.900335] [vc_sm_connected_init]: start
[ 0.902996] [vc_sm_connected_init]: end - returning 0
[ 0.908034] Waiting for root device /dev/mmcblk0p2…
[ 0.938059] mmc0: host does not support reading read-only switch, assuming write-enable
[ 0.940157] mmc0: new high speed SDHC card at address 0001
[ 0.940733] mmcblk0: mmc0:0001 SD16G 14.6 GiB
[ 0.942057] mmcblk0: p1 p2
[ 1.024582] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.024632] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.034029] devtmpfs: mounted
[ 1.034491] Freeing unused kernel memory: 412K (80961000 - 809c8000)
[ 1.050727] Indeed it is in host mode hprt0 = 00021501
[ 1.230627] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.230772] Indeed it is in host mode hprt0 = 00001101
[ 1.430923] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.430946] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.431769] hub 1-1:1.0: USB hub found
[ 1.431903] hub 1-1:1.0: 5 ports detected
[ 1.710709] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.811147] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.811177] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.814363] smsc95xx v1.0.4
[ 1.875110] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:05:7f:97
[ 1.950666] usb 1-1.3: new high-speed USB device number 4 using dwc_otg
[ 2.052185] usb 1-1.3: New USB device found, idVendor=05e3, idProduct=0606
[ 2.052217] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.052234] usb 1-1.3: Product: USB2.0 Hub
[ 2.053559] hub 1-1.3:1.0: USB hub found
[ 2.053906] hub 1-1.3:1.0: 4 ports detected
[ 2.330743] usb 1-1.3.3: new high-speed USB device number 5 using dwc_otg
[ 2.434260] usb 1-1.3.3: New USB device found, idVendor=1bcf, idProduct=0c31
[ 2.434293] usb 1-1.3.3: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2.434310] usb 1-1.3.3: Product: USB to Serial-ATA bridge
[ 2.434328] usb 1-1.3.3: Manufacturer: Sunplus Innovation Technology.
[ 2.434344] usb 1-1.3.3: SerialNumber: FFFFCFFF0CF8FF6FFC100FFF
[ 2.436959] usb-storage 1-1.3.3:1.0: USB Mass Storage device detected
[ 2.437810] scsi host0: usb-storage 1-1.3.3:1.0
[ 2.510661] usb 1-1.3.4: new high-speed USB device number 6 using dwc_otg
[ 2.612110] usb 1-1.3.4: New USB device found, idVendor=05e3, idProduct=0606
[ 2.612141] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.612157] usb 1-1.3.4: Product: USB2.0 Hub
[ 2.613452] hub 1-1.3.4:1.0: USB hub found
[ 2.613793] hub 1-1.3.4:1.0: 4 ports detected
[ 2.644093] random: systemd urandom read with 76 bits of entropy available
[ 2.722601] NET: Registered protocol family 10
[ 2.890650] usb 1-1.3.4.1: new high-speed USB device number 7 using dwc_otg
[ 2.991761] usb 1-1.3.4.1: language id specifier not provided by device, defaulting to English
[ 2.993785] usb 1-1.3.4.1: New USB device found, idVendor=0572, idProduct=c688
[ 2.993809] usb 1-1.3.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.143378] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.143741] systemd[1]: Found ordering cycle on basic.target/start
[ 3.143774] systemd[1]: Found dependency on sysinit.target/start
[ 3.143803] systemd[1]: Found dependency on kbd.service/start
[ 3.143831] systemd[1]: Found dependency on remote-fs.target/start
[ 3.143856] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.143881] systemd[1]: Found dependency on connman.service/start
[ 3.143906] systemd[1]: Found dependency on dbus.service/start
[ 3.143930] systemd[1]: Found dependency on basic.target/start
[ 3.143956] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 3.143986] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.144341] systemd[1]: Found ordering cycle on basic.target/start
[ 3.144373] systemd[1]: Found dependency on sysinit.target/start
[ 3.144402] systemd[1]: Found dependency on rpcbind.service/start
[ 3.144431] systemd[1]: Found dependency on network-online.target/start
[ 3.144456] systemd[1]: Found dependency on network.target/start
[ 3.144481] systemd[1]: Found dependency on connman.service/start
[ 3.144505] systemd[1]: Found dependency on dbus.service/start
[ 3.144529] systemd[1]: Found dependency on basic.target/start
[ 3.144554] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 3.144584] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.289475] fuse init (API version 7.23)
[ 3.370168] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.434092] scsi 0:0:0:0: CD-ROM TSSTcorp CDDVDW SN-208BB SB01 PQ: 0 ANSI: 0
[ 3.581127] systemd-udevd[127]: starting version 215
[ 3.931467] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.131335] usbcore: registered new interface driver uas
[ 4.210500] sr 0:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 4.210533] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 4.218606] sr 0:0:0:0: Attached scsi CD-ROM sr0
[ 4.225207] dvb-usb: found a ‘Mygica T230 DVB-T/T2/C’ in warm state.
[ 4.230238] sr 0:0:0:0: Attached scsi generic sg0 type 5
[ 4.434410] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.473692] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 4.474609] DVB: registering new adapter (Mygica T230 DVB-T/T2/C)
[ 4.520030] i2c i2c-3: Added multiplexed i2c bus 4
[ 4.520062] si2168 3-0064: Silicon Labs Si2168 successfully attached
[ 4.559065] si2157 4-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 4.559154] usb 1-1.3.4.1: DVB: registering adapter 0 frontend 0 (Silicon Labs Si2168)…
[ 4.561092] input: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.1/input/input0
[ 4.561133] dvb-usb: schedule remote query interval to 100 msecs.
[ 4.561616] dvb-usb: Mygica T230 DVB-T/T2/C successfully initialized and connected.
[ 4.561830] usbcore: registered new interface driver dvb_usb_cxusb
[ 5.064556] random: nonblocking pool is initialized
[ 5.506656] systemd-journald[104]: Received request to flush runtime journal from PID 1
[ 6.115261] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 6.115635] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.631243] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.633174] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 7.657736] 8021q: 802.1Q VLAN Support v1.8
[ 11.166907] Console: switching to colour dummy device 80x30
[ 20.476739] si2168 3-0064: found a ‘Silicon Labs Si2168-B40’
[ 20.489232] si2168 3-0064: downloading firmware from file ‘dvb-demod-si2168-b40-01.fw’
[ 20.489272] si2168 3-0064: firmware download failed -22
[ 20.498698] si2157 4-0060: found a ‘Silicon Labs Si2158-A20’
[ 20.503117] si2157 4-0060: firmware file ‘dvb-tuner-si2158-a20-01.fw’ is invalid
[ 20.503300] usb 1-1.3.4.1: DVB: adapter 0 frontend 0 frequency 0 out of range (55000000…862000000)
[ 20.776486] si2168 3-0064: found a ‘Silicon Labs Si2168-B40’
[ 20.776825] si2168 3-0064: downloading firmware from file ‘dvb-demod-si2168-b40-01.fw’
[ 20.776849] si2168 3-0064: firmware download failed -22
[ 20.786064] si2157 4-0060: found a ‘Silicon Labs Si2158-A20’
[ 20.786358] si2157 4-0060: firmware file ‘dvb-tuner-si2158-a20-01.fw’ is invalid
I have reached the limit of my knowledge and would appreciate any help the community can provide
