For years my external WD drive was mounted automatically in /media/WD/. A few weeks back it stopped. Turns out the USB drive is being mounted when plugged-in while the Pi is running but not when already plugged-in during reboot.
Tried a few other USB drives, same issue.
Has someone an idea how to fix this issue?
Just some ideas:
- Aged or wrong power supply to the Pi?
- Already tried with a self-powered USB hub between the Pi and HDDs?
Also some logs could help to help you:
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
- publish the provided URL from the log set upload, here
