I am using Vero4k+ and I just updated to the latest release (2020.10-1) this morning and I’m now having 2 issues:
My WdElements 12TB external hard drive does not mount automatically anymore, here is what I have in fstab: UUID=96b7efb3-4ab3-45ea-9b2f-eecbd458138b /mnt/elements ext4 nofail,x-systemd.device-timeout=5,noatime 0 0
I checked and the fstab UUID matches the device UUID, here is output of blkid: /dev/sda1: LABEL="elements" UUID="96b7efb3-4ab3-45ea-9b2f-eecbd458138b" TYPE="ext4" PARTLABEL="Elements" PARTUUID="c5934aef-8628-476d-853d-3132dfddf9bc"
It doesn’t mount it even if I reboot the system, I have to manually mount it with sudo mount /dev/sda1 /mnt/elements/ -t ext4
I was running docker with a few containers and it seems like the docker daemon stopped working after this update, when I docker ps I get this error: Cannot connect to the Docker daemon at unix:///var/run/docker.sock. Is the docker daemon running?
After checking sudo service --status-all it seems like docker isn’t running, so I tried to reset it with systemctl but it didn’t work and didn’t give me any useful info, so I checked what sudo dockerd --debug outputs:
Not sure if this will fix the docker problem or not, but it seems to loading iptables-legacy rules; where as buster loads nfttables by default. Please try this:
sudo update-alternatives --config iptables
When prompted (Press to keep the current choice[*], or type selection number) enter 1.
As for fstab mount:
reproduce the issue
I’ve tried your docker solution with update-alternatives and it worked. However, all of my containers changed the status to dead and I had to recreate them. Now I get this error anytime I try to run any containers again:
docker: Error response from daemon: unable to find "net_prio" in controller set: unknown.
I googled about it a bit and it seems like people are recommending to rebuild the kernel:
To fix it on my system I just needed to rebuild my kernel with CONFIG_CGROUP_NET_PRIO enabled
Did something like this change in the new october release?
Regarding the fstab issue, I will post the logs later on, when I get the time to prepare everything… I can manage with manual mount atm, but docker sucks a bit.
Regarding auto mounting issue, I found this error in the logs:
Nov 16 18:31:46 osmc udisks-glue[281]: Failed to automount /dev/sda1: Error mounting: mount exited with exit code 1: helper failed with:
Nov 16 18:31:46 osmc udisks-glue[281]: mount: /mnt/elements: operation permitted for root only.
It seems like some permission changed with the newest update? No idea. I have fixed the fstab issue by changing the /etc/fstab entry and adding the user option:
It’s difficult to see how that would have fixed the issue, since root is already mounting the disk. I think a more likely source of the problem is your use of x-systemd.device-timeout. I’ve seen this produce the same error in Buster (Debian and RaspiOS) and would recommend that you change it to x-systemd.automount,noauto.
As to the kernel cgroups issue, it looks like Sam omitted it from the 3.14 kernel (and also from the Pi2/3 kernel).
Edit: fixed typo - nauto should be noauto. D’oh! Cheers @ooZee.
OK, I now actually see what @bmillham was trying to say. So I tried both of your solutions:
first I tried to change x-systemd.device-timeout=5 to x-systemd,device-timeout=5 and it stopped mounting again,
then I also tried your solution @dillthedog and I added x-systemd.automount,nauto and it also didn’t work…
I’ve reverted the change as it seems like my solution is the only one that works, tbh I can’t be bothered with this issue anymore…
Regarding cgroups issue, it seems like some people had luck by downgrading systemd to <240 version, it seems like the current version is 241. Would that be possible? Am I basically stuck without docker on the latest october release? Kind of sucks, I will probably be forced to downgrade
I am just guessing - I have also checked my docker-ce and containerd.io installation and it seems like I have the latest version for debian, so I guess this problem has not been fixed by docker yet.
I have found a lot of similar issues with systemd where people report success on <240 versions:
