Hello,
All of my devices will auto-switch except the Vero 4k for me. Am I missing something? All settings are at default, and nothing is glaring that I should be changing.
Yamaha AVR and stock Vero/remote.
Thanks!
Hello,
Thanks!
Do you mean that you want the TV to change the source when you power the device?
Yes I’m running all devices through my AVR. I leave the Vero on always. So I’m hoping to get the AVR to switch to Vero HDMI input when i hit any button on the Vero remote.
In settings>system>input>peripherals>CEC adapter> you will find all the CEC settings available to tweak on the Vero side. You will probably have to do some trial and error to find settings that work for your particular setup.
