Both logs, current boot and last boot, indicate you have navigated to the second screenshot here but have NOT selected “Check for updates”.
11:21:21 19.615728 T:1956697008 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0 11:21:21 19.615837 T:1956697008 DEBUG: OnKey: right (0xf083) pressed, action is Right 11:21:22 20.222654 T:1956697008 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0 11:21:22 20.222801 T:1956697008 DEBUG: OnKey: right (0xf083) pressed, action is Right 11:21:22 20.602133 T:1956697008 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0 11:21:22 20.602301 T:1956697008 DEBUG: OnKey: long-right (0x100f083) pressed, action is Right 11:21:26 23.272562 T:1956697008 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0 11:21:26 23.434071 T:1956697008 DEBUG: OnKey: return (0xf00d) pressed, action is Select 11:21:26 23.434313 T:1956697008 DEBUG: Activating window ID: 10004 11:21:26 23.671875 T:1956697008 DEBUG: ------ Window Deinit (Home.xml) ------ 11:21:26 23.685404 T:1956697008 DEBUG: ------ Window Init (Settings.xml) ------ 11:21:26 23.685493 T:1956697008 INFO: Loading skin file: Settings.xml, load type: KEEP_IN_MEMORY 11:21:26 23.779001 T:1756820464 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x6f305d90 11:21:26 23.779995 T:1756820464 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(402672), nBufferAlignmen(16) 11:21:26 23.803631 T:1756820464 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x6f3269c0 11:21:26 23.804422 T:1756820464 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16) 11:21:26 23.831581 T:1756820464 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.image_decode handle 0x6f305d90 11:21:26 23.832598 T:1756820464 DEBUG: COMXCoreComponent::Deinitialize : OMX.broadcom.egl_render handle 0x6f3269c0 11:21:26 23.832756 T:1756820464 DEBUG: DecodeJpegToTexture: decoded special://skin/backgrounds/settings.jpg 1024x576 11:21:27 24.748604 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:27 24.748735 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:27 24.985975 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:27 24.986116 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:28 25.168728 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:28 25.168882 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:28 25.355255 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:28 25.355394 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:28 25.545254 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:28 25.545389 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:28 25.998810 T:1956697008 DEBUG: Keyboard: scancode: 0x6c, sym: 0x0112, unicode: 0x0000, modifier: 0x0 11:21:28 25.998968 T:1956697008 DEBUG: OnKey: down (0xf081) pressed, action is Down 11:21:29 26.643972 T:1956697008 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0 11:21:29 26.775532 T:1956697008 DEBUG: OnKey: return (0xf00d) pressed, action is Select 11:21:29 26.775742 T:1956697008 DEBUG: Activating window ID: 10040 11:21:29 27.039890 T:1956697008 DEBUG: ------ Window Deinit (Settings.xml) ------ 11:21:29 27.056377 T:1956697008 DEBUG: ------ Window Init (AddonBrowser.xml) ------ 11:21:29 27.056515 T:1956697008 INFO: Loading skin file: AddonBrowser.xml, load type: KEEP_IN_MEMORY 11:21:30 27.213009 T:1956697008 DEBUG: CGUIMediaWindow::GetDirectory () 11:21:30 27.213125 T:1956697008 DEBUG: ParentPath = [] 11:21:30 27.274574 T:1594872816 DEBUG: Thread BackgroundLoader start, auto delete: false 11:21:30 27.277813 T:1594872816 DEBUG: Thread BackgroundLoader 1594872816 terminating 11:21:32 29.182703 T:1956697008 DEBUG: Keyboard: scancode: 0x69, sym: 0x0114, unicode: 0x0000, modifier: 0x0 11:21:32 29.182877 T:1956697008 DEBUG: OnKey: left (0xf082) pressed, action is Left 11:21:34 31.185421 T:1956697008 DEBUG: Keyboard: scancode: 0x6a, sym: 0x0113, unicode: 0x0000, modifier: 0x0 11:21:34 31.185545 T:1956697008 DEBUG: OnKey: right (0xf083) pressed, action is Right 11:21:37 34.132648 T:1956697008 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0 11:21:37 34.132786 T:1956697008 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 11:21:37 34.132885 T:1956697008 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 11:21:37 34.388794 T:1956697008 DEBUG: ------ Window Deinit (AddonBrowser.xml) ------ 11:21:37 34.402016 T:1956697008 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 11:21:37 34.402126 T:1956697008 DEBUG: ------ Window Init (Settings.xml) ------
