hi. In Kody Krypton where you can block the automatic scrolling of the text of the movie plot?
Which skin are you using? It will be different and potentially not possible in different skins.
Estuary
I didn’t want to open a new topic for this: where can I disable this in the OSMC skin? When enabled, it brings the temperature up to 80°C while idle, opposed to about 60°C in the main menu without any scrolling going on.
Thanks!
The device should be fine at 80°C. There’s no simple way to do this.
