Hello, i have OSMC based on Raspberry. Everything works, but sometimes happen that IPTV stream stopps, then systems returns to menu and waits. Is possible to let system restart stream automatically ?
many thanks
Ed
many thanks
Ed
Have you tried contacting the IPTV Addon provider? That would be your best bet.
Hi, i did and answer was : You have probably illegal stream
Good luck with that then.
I am bulldog, i found source code of Simple IPTV, will try to fix it myself
