Hi All,
I thought it maybe worth posting this up for information purposes only.
The backgound!
I have 2 RPI’s, one of which was setup as an openvpn server. I recently had to reinstall so lost the function.
Roll on a few months and I decided to turn both of them into openvpn servers. Obviously I can only use one through the router. So I decided to remove the packages I had installed on the redundant PI.
I ran apt-get autoremove and answered Y. Didn’t check the screen so it removed the following:
armv7-bluez-osmc
armv7-connman-osmc
armv7-network-osmc
cifs-utils
curl
easy-rsa
gir1.2-glib-2.0
iproute2
libelf1
libgirepository-1.0-1
libnl-3-200
libnl-genl-3-200
libnss-myhostname
libpcsclite1
libpkcs11-helper1
net-tools
openvpn
python-dbus
python-gi
python-gobject
python-gobject-2
rbp2-device-osmc
samba-common
wget
wireless-firmware-osmc
wpasupplicant
PI runs and the screen shows Kodi. Obviously the network is down but I’ve found a page that looks like it will help.
Failing that I’m more than happy to reinstall as I have it setup to access a local mysql db rather than local db.
I decided to do some checks on the remaining working PI with openvpn and it looks like there is a difference in what is removed depending on the command issued.
apt-get autoremove
does nothing as there is nothing to remove.
apt-get autoremove openvpn easy-rsa
ended with the removal of the above.
Oh well. Live and learn and it’s not like I’m going anywhere in lockdown!
BBloke
