Hi all,
I just bought an AV receiver and it doesn’t like the Vero 4k one bit. I get video until the OSMC splash screen and then it all goes black.
The Vero works just fine if I connect it to my TV.
I have a Marantz SR5015
See below recommendation on configuration.
Maybe easiest to connect back to the TV make those changes and then reboot before connecting to AVR
We recommend people with 4K TV’s set their user interface (UI) to 1080p. Kodi’s UI is not optimized for 4K yet and this can put unnecessary demands on your device and can lead to a suboptimal picture quality, as well as potentially cause other issues.
With the above settings your UI will be output in Full HD and your 4K content will be output in 4K. *Information regarding the whitelist can be found here. If you have any doubt, feel free to upload some logs so we can verify that your settings are indeed correct.
Hi, thanks for the quick reply.
Should i also try the new kodi version that is available in development branch? I saw there are some video improvements.
