Hello!
Is this a known issue? After the upgrade, I am facing sync issues with AVI files. Not the case with MKV files. I did a quick search in the forum and didn’t see any related recent entry. Thanks!
reproduce the issue
upload the log set (all configs and logs!) either using the
Thank you very much for the answer.
I followed all the steps and here are the requested files: https://paste.osmc.tv/ugifaqokab
I reboot twice. Then I selected series, a specific one from the list, and pushed play. It started and I stopped it after 1 minute. As I said, the video and audio are out of sync. It happens with all AVI files I tested. It doesn’t happen with MKV files.
Before the upgrade, this didn’t happen. I suspect there has been a change in installed codecs perhaps?
Well, there are all the logs. I hope you can help me detecting the issue. I will have to reinstall the old version if it is not solved, so thanks a lot for your help.
Ok, investigating a little bit myself within the settings I found “the issue”.
The sync issue disappears if I unselect: “Allow hardware acceleration with DRM PRIME” or having it selected but then also select “Only allow acceleration for HEVC”.
Does it make sense? Any idea why does it happening? I am not an expert, I don’t know what DRM PRIME does and why it should affect to AVI files. Is it anything new in this update?
BTW, I am using a Raspberry Pi 3.
Thanks again!
New issue. If I do what I explained above I fix AVI files but I break MKV ones. :-/
So I need to touch that setting each time, it depends if I am going to see an AVI or a MKV file.
Any idea or suggestion why is this happening?
Thanks!
Did you ever find a solution for this? I’ve been running into the exact same issue.
No. I had to came back to previous version and I am still stuck on it. I won’t buy Pi 4 at the moment just to upgrade Kodi.
So according to Rainman74 in this thread HERE, you can use a “decoderfilter.xml” file that can disable hardware acceleration for any video file less than 600 pixels in height.
That SHOULD fix the problem, however I’m having difficulty finding documentation about the decoderfilter.xml file itself. I copied the one that’s posted in that thread, but so far it doesn’t seem to do anything. I assume I need to adjust it somehow but without documentation it’ll be difficult.
