By default samba shares osmc folder and external units mount under /media/ path. How to avoid samba mounts media units?.
I have osmc and retropie system in the same SD card, and retropie system folders are mounted under media when I boot on osmc (I want to avoid share these foldres).
I’ve just noticed that smb.conf automatically gets overwritten and changes destroyed on updates anyway possibly on reboot though I’m not 100% sure.
Try this instead:
Create a new file called smb-local.conf in the same directory as smb.conf (/etc/samba/) and insert the following lines:
[global]
#If you only need to add some additional shares see smb-shares.conf below for a simpler way to do this.
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
# usershare template share = automount template
# Automount template disabled to work around a samba bug causing crashes accessing external drives.
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
comment = OSMC Home Directory
#[automount template]
# browseable = yes
# -valid = no
# valid users = osmc
# path = %P
# hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
Let me know if it works? If it doesn’t I could be due to udisk-glue automatically still automatically generating the shares in which case to prevent updating that file you could try changing smb-local.conf to:
[global]
security=user
wide links = no
load printers = no
printing = bsd
log level = 1
read raw = Yes
write raw = Yes
strict locking = no
use sendfile = true
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
browseable = no
-valid = no
valid users = osmc
path = %P
That last fix is more of a workaround and only should be used if the first fix doesn’t work as it still leaves the shares open just invisible.
Unfortunately I’m not quite sure how to proceed then if I’m honest. I would have thought that editing those files would have worked though if not then Samba must be configured elsewhere. Maybe one of the devs can best answer this? @sam_nazarko ? @DBMandrake ?
