Backup between Vero4K+ and RasPi4
Hello,
I would like to use my RasPi 4 to test some changes to the Kodi UI (I’m mostly using Aeon Nox Silvo skin), while using Vero 4K as main ‘running’ unit.
Obviously both with same OSMC version.
  1. Can I make a backup on the Vero, and restore it on the Pi?
  2. If step 1 is ok, can I modify something on the Pi and after testing, via backup propagate the change back to the Vero ?
Yes
Yes
I would be wary of changes to guisettings.xml because the HW acceleration options are different on these platforms.
