Time has come, end of support for ATV1 is here. As long as possible you supported this nice piece of hardware, but the effort cannot be endless. A wise decission to put energy in future projects…
In the last update (August) the MyOSMC menu was stripped from the possibility to make updates. So far , so good. With this step the possibility to make and restore backups also disappeared - not so good
Is there a way to reactivate this menu and only set ‘check for updates’ to never?
Thanks for the long support
Stefan
