Is there some possibilities to add backup of TV headend to MyOSMC Backup Tools?
In form of special checkbox for TVH or some user selected directory for backup?
I´ve found this thread:
Not sure if wil working user selected directory if the TVH service not stopped
In the past if I made backup by MyOsmc tool, I have also backup of Confluence setting (shortcuts etc.), but last time when I made backup, these setting was not included. There was some change in this tool?
I already try to copy of directory, but it not working - not all files was copied.
I´m not sure if there was some problem with access rights or running tvheadend services.
I will test again.
Jan
I recently backed up tvheadend and moved it it different vero4k, I just tar.gz(ed) it and then decompressed it on the other device and it all worked fine:
Edit: @JanS, @bmillham has just reminded me that tvheadend should be stopped to backup/restore, so the process should be:
To backup:
sudo systemctl stop tvheadend cd ~ tar -czvf tvheadend-backup.tar.gz .hts systemctl start tvheadend
To restore:
systemctl stop tvheadend cd ~ rm -rf .hts tar -xzvf tvheadend-backup.tar.gz systemctl start tvheadend
The comand: rm -rf .hts will fail if restoring backup to fresh install.
I’m a little late to this post, but the below linked wiki guide really helped me to just download the whole .hts directory over sftp, using Filezilla. Hope it helps someone else.
