Banding on LG OLED C7 with HDR
I’m using the latest november update on my Vero 4K and I’ve just noticed some banding when watching HDR movies. I don’t remember noticing it since many months ago when it was fixed by a hotfix.
What should I provide to be able to get some help ? Debug log while watching some of these videos ?
Thank you !
Do you know how to use SSH?
yes
I would double check to make sure on your TV you have ULTRA HD Deep Color enabled for the input the Vero is plugged into.
Can you run cat /etc/rc.local and paste the output?
osmc@osmc:~$ cat /etc/rc.local
#!/bin/sh -e
# rc.local
# This script is executed at the end of each multiuser runlevel.
# Make sure that the script will “exit 0” on success or any other
# value on error.
# In order to enable or disable this script just change the execution
# bits.
# By default this script does nothing.
exit 0
It is enabled I’ve just checked thank you.
how about cat /sys/class/amhdmitx/amhdmitx0/config when a video is playing?
and/or post full debug logs.
osmc@osmc:~$ cat /sys/class/amhdmitx/amhdmitx0/config
AVIF VIC: 0
VIC: 93 3840x2160p24hz
Colour depth: 10-bit
Colourspace: YUV444
Colour range: limited
EOTF: HDR10
YCC colour range: limited
PLL clock: 0xc000029a, Vid clock div 0x000b0000
Aspect ratio: 16:9/full frame
Audio config: on
3D config: off
I can post a debug later if needed.
Yes, please.
sorry it took so long
https://paste.kodi.tv/ekonivahuz.kodi
Please use the log uploader in MyOSMC.
And if you can, upload a clip from the movie where you are seeing this banding.
Please tell me if I can assist further.
https://paste.osmc.tv/obahayotoc
https://ufile.io/zal71ksf
