touchscreen only works when touching starts on left top corner. otherwise when i touch the screen the cursor appear on top left screen. works when i touch the cursor on top left corner and tap or drag it.
i think its about alignment or calibration but i dont know how to solve it. anyone can help ? thanks
its the calibration log in ubunto that this touchscreen worked correctly in there.
i think there is all the information i know in this moment.
The touchscreen connected to a mini board and from there, connected to raspberry pi. in raspbian and ubunto i had no problem.
i dont calibrate it myself. i just ran this command earlier to see the touchscreen model and info. touchscreen was calibrated by default in raspbian and ubuntu
Actually using osmc 2018-12-1 with nebula skin, raspberry pi 3B, official 7" touch screen.
I figured out today that mainly, mouse cursor and touch interaction are independant but …
Default location of mouse cursor (top left) interact with the top “option bar” with a sort of roll over behavior. When i touch the screen this mouse cursor interfere with the expected action.
If i simply move one time that mouse cursor elsewhere with a mouse or rii remote, the touchscreen is working perfectly.
As i want to use alternatively touch feature and rii remote as mouse, i will look for changing the default position of mouse cursor.
