Hello All
Simple question
what is the best way to migrate from raspberry Pi to Vero 4k ?
backup of the library on the pi and restore to the Vero 4K ?
I am sure some of you have already done that
thank you
Hello All
Simple question
thank you
Use the MyOSMC backup tool to backup to USB stick or NAS and restore it on the Vero4k
That will take care of all your Mediacenter stuff.
Many thanks for the tip
it worked perfectly !!!
