Best storage unit
Which is the best storage unit to be used mainly for downloading (I was thinking about 8 to 16 GB max)? USB pen drive or SD card? If USB, which one?
Thanks for suggestions.
NAS is always preferable then local storage
Thanks Toast. I’m using a NAS for all my files. I prefer to have a local storage only for downloads.
Sandisk makes good usb drives
You could look at picking up a portable hard drive for a reasonable price.
Best is hard to clarify though, because everyone’s storage needs will be different.
The WD Pi drive works for most devices dunno if vero 2 has micro usb however :slight_smile:
