I just upgraded to OSMC Kodi V19.1 (RPi3).
When I am looking up subtitle plugins - most old plugins are missing and I am not familiar with most new names in the list.
Before updating to Kodi v19.1, BSPlayer subtitle and Podnapisi used to work for me on OSMC. Subscene or Opensubtitles almost never worked.
Which subtitle plug in do you guys use that works well for you?
Opensubtitles.org changed their api policy at the start of this year. It was working prior to that. You would need to disable or uninstall the old opensubtitles.org subtitle add-on and install the newer opensubtitles.com add-on.
