Best twin satellite (DVB-S2) tuner for Vero4K?
Hi. As per the heading I am looking to use my Vero4K as a recordable freesat device in the UK.
I could just buy a Humax freesat box but would like it integrated into the Vero4K so I can use the same interface for live and recorded HD TV.
Can anyone recommend a suitable device (I will be recording to my Synologu NAS). I would prefer it to be simple! Thanks
A Sundtek tuner is good, but I don’t know if they’re dual tuner.
Thanks Sam - but I can’t find any sundtek ones that will work with satellite.
These may be the devices you are looking for.
Thank you
