Best way to downgrade OSMC version
I would like to downgrade my two Vero 4K+ devices to the last Kodi 20 release (this should be the June '24 version if I’m not mistaken).
What’s the easiest way to do this? The images for this release are not online anymore, Is it possible via the command line?
Thanks!
All images are online at Index of /osmc/osmc/download/installers/diskimages.
Not possible via the command line.
Thanks! It worked nicely.
Do I get thid right: So to downgrade to a previous version it would be a complete reinstall?
No way to quickly revert to a previous build without loosing complete settings and dbs, which will need to be restored from backup or so?
Yes
If you want to keep your userdata it would need to be backed up and restored onto the reinstalled version.
