So I was curious as to how well this would run on the Vero 4K or 4K Plus, and…well - it doesn’t. Hundred of skipped frames, CPU looks like it’s pegged at times.
This is the only 60fps UHD BD that I’m aware of, and was ripped from the original disc.
Anyone else got this one working?
Can you show us MediaInfo?
Yep. Was being weekend-lazy in the hope it was a known issue.
Format : Matroska
Format version : Version 2
File size : 72.0 GiB
Duration : 1h 52mn
Overall bit rate : 91.4 Mbps
Movie name : Billy Lynn's Long Halftime Walk
Encoded date : UTC 2018-09-15 18:17:24
Writing application : MakeMKV v1.12.2 darwin(x64-release)
Writing library : libmakemkv v1.12.2 (1.3.5/1.4.7) darwin(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1h 52mn
Bit rate : 86.4 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.174
Stream size : 68.1 GiB (95%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Original source medium : Blu-ray
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 2086 cd/m2
Maximum Frame-Average Light Level : 997 cd/m2
I havn’t played all of it but the bits of it I tested seemed to play fine from an nfs share. Have you tried playing it from usb?
Would be good to see a debug log then.
Nothing looks abnormal with the clip
I can upload a clip if that’s easier? I feel like it usually is…
72GB might be a bit large.
Can you give us a 500MB or so clip that can reproduce the problem?
Yep, where do you want it?
Played bits of it earlier without issues as well
Hmm. Well I sent a sample to Sam so we’ll see what he says… Unless I did something wrong ripping it I don’t know what else it would be.
From the start of the movie, when would you have the first skip?
I skipped ahead to around 5-6 minutes in. It’s skipping in the magnitude of 10-or-so every second. With the cache window open, it’s really easy to see the steady count upward of frame issues. Cache is solid.
Hopefully Sam can check on the sample at some point.
I had 5 skips during 5 minutes (05:00 - 10:00) didn’t even notice them.
Cache was indeed steady and the bitrate didn’t even peak that much either.
Hm. Better than me, but still not good. We’ll see what Sam says.
