Did you try the toothpick method?
No I haven’t
Should I try the toothpick method
I’m still dealing with the same issue I’ve tried usb 2 new sd cards still nothing
I moved this from the new thread you started on the same topic with the same title. Please do not do this in the future.
I would recommend trying the toothpick method which involves renamijng the device to recovery.img. If this fails, you can start a support request and we will get the device back for inspection
Try another display / make sure the cable is connected directly to the TV as a test
