I have an issue with the with Blu-ray ISO playback because I cannot playback about half of my collection. Some ISOs working perfectly but others not. Unfortunately I cannot figure out the root of the problem. Here is a piece of the Kodi log when tried to start play a title which is not work:
Yes, I can. So I made a modificated ISO wherein I replaced the main title to a menu piece. I tested with A400 and that is work with it. The size around 1.5 GB, how can I pass to you?
But it won’t play with kodi on Ubuntu, vlc or mplayer. Have you removed the encryption when ripping it? Kodi doesn’t support encrypted BluRay ISOs. Tools like AnyDVD and DVDFab can remove encryption. makemkv is another option for ripping BluRay files losslessly.
So, I am more or less sure the BD have no AACS encryption… (I did not find any tool to check this)
I checked the BD ISO content with VLC and it is can play the main feature (0020.m2ts) both from the original and the modified image. But VLC cannot play the ISO itself and I have no experience in this…
Just in case, I created a new ISO with DVDFab copy function from the modified image (AACS removing option turned ON (as always)). I tested again with VLC:
Play ISO: VLC freeze
Mounted ISO: 0020.m2ts: plays fine.
RPi2 Kodi: ISO plays fine… Ooopsss…
I shaered this second image with you also.
As I known both image have no AACS encoding, so what could be the difference? Why the first IOS do not work with Kodi but the second ISO is yes?
Added: I tested the DVDFab copy with the original BD and the new ISO is also worked on Kodi… Strange…
I can’t say what is wrong with the broken ISO file.
Even mounting the ISO file and then trying to play one of the m2ts files fails with all players I own (I get a single frame of video then nothing, but I hear audio).
So this isn’t a Kodi / Pi playback issue, it’s a ripping ISO issue, but afraid I don’t know what the solution is.
Sorry for any inconvenience but that is what you should see. As I mention earlier I replaced the main feature with an element from the menu… So if you can play the 0020.m2ts (which is only a static picture and a short music) is great, but why Kodi cant play?
Okay, I hadn’t realised the video files are dummy.
It does seem that all versions of kodi behave the same (e.g. kodi on Ubuntu fails the same way),
so it may be best to post in general kodi forum and see if any of the devs have suggestions.
