I’m using OSMC on my Raspberry Pi 2 and any file I ripped myself using a BD won’t play the built in subs. I tested a file and downloaded an external SRT and muxed it together and that works. Is there something I can do to get them to work?
Edit: All the movies tested work on Vero 4K+ and my computer.
Are these muxed into a mkv or external? I’m not aware of any issues with idx/sub files. If external are they named correctly?
https://kodi.wiki/view/Subtitles
They’re ripped straight from the disc. No muxing at all. I only rip the English tracks and forced subs.
How are you ripping the blurays?
Thanks Tom.
Make MKV - works perfectly on my Vero 4K+ and Mac.
reproduce the issue
https://paste.osmc.tv/oyulomacat
Logs above. Oddly as you can see sometimes the subs work and sometimes they don’t even selecting the same movie multiple times. Every movie I played was ripped by me from a disc.
Edit: Also noticed it’s not playing the subtitle track by default. Maybe I’m missing a setting but I selected subs enabled and changed the languages to English. Set default for all media. Not sure why it’s happening. I know the pi2 is old at this point. Might be time for a second vero lol.
I think there is (was) an issue with MakeMKV where the forced subs were not marked as the default or forced sub. I seem to remember having to use MKVToolNix to fix it. I’d have to go back and look as some rips to see exactly what I did.
Any movie that has forced subs I manually select the forced track in MKVToolNix. But my wife likes full subs so even if I a movie has forced we watch with regular subs.
I experimented with this a little, and the only way I can get the forced subs to work reliable is to set the sub track to default,forced. If I just set it to forced, the subs don’t seem to show unless I enable them. I suspect that this may be a Kodi bug. I will do some more testing to try and narrow down what’s happening.
It’s not an issue specifically with forced subs, it’s any subs. Even when I enable them from the app. They just don’t show up on screen.
