Hi at all…
thank’u for your great job.
I’m a newbie and please help me.
all it’s go very well but when i use my andnroid phone via bluethoot for play my music, i listen only on HDMI but i have installed an USB Dac that i can set and use if have a local audio file on SD or external device.
Where i can set the audio bluethoot output?
I use OSMC on PI4 8 GB and my USB Dac it’s integrated into Technics Amplificator.
Thank
Hi everyone…
i used all the info to setup my bluethoot audio output to USB DAC but i don’t hear anything anywhere.
This is my sudo nano /lib/systemd/system/bluealsa-aplay.service file
GNU nano 5.4 /lib/systemd/system/bluealsa-aplay.service
[Unit]
Description=A2DP playback
After=bluealsa.service syslog.service
Requires=bluealsa.service
StopWhenUnneeded=true
[Service]
ExecStartPre=/bin/sleep 3
ExecStart=/usr/bin/bluealsa-aplay -D front:CARD=Audio --profile-a2dp 00:00:00:0>
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=A2DP playback
Restart=on error
[To install]
WantedBy=bluetooth.target
this is my game -l
**** PLAYBACK Hardware Device List ****
card 0: vc4hdmi1 [vc4-hdmi-1], device 0: NEVER PCM i2s-hifi-0 [NEVER PCM i2s-hifi-0]
Subdevices: 1/1
Subdevice #0: Subdevice #0
tab 1: Audio [Technics USB Audio], device 0: Audio USB [USB Audio]
Subdevices: 1/1
where is the problem?
thank’u
GNU nano 5.4 /lib/systemd/system/bluealsa-aplay.service *** I don’t recognise this line - it shouldn’t be in the file ***
[Unit]
[Service]
*** should be
ExecStart=/usr/bin/bluealsa-aplay -D front:CARD=‘Audio USB’ --profile-a2dp 00:00:00:00 StandardOutput=syslog
Restart=on error
[To install] *** should be just [Install]
and after changing this file
sudo systemctl daemon-reload
sudo systemctl restart bluealsa-aplay
Please try sudo apt-get install --reinstall armv7 -bluez-osmc
Nothing it’s changed. From my HDMI for BT music all ok and if simultaneously i played the local FLAC i can listen on USB amplifier.
this is my log
bluealsa-aplay.service - A2DP Playback
Loaded: loaded (/lib/systemd/system/bluealsa-aplay.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2023-04-16 11:58:56 CEST; 3s ago
Process: 1603 ExecStartPre=/bin/sleep 3 (code=exited, status=0/SUCCESS)
Main PID: 1604 (bluealsa-aplay)
Tasks: 2 (limit: 1597)
CPU: 53ms
CGroup: /system.slice/bluealsa-aplay.service
└─1604 /usr/bin/bluealsa-aplay -D dmix:CARD=Audio --profile-a2dp 00:00:00:00:00:00
apr 16 11:58:53 osmc systemd[1]: Starting A2DP Playback…
apr 16 11:58:56 osmc systemd[1]: Started A2DP Playback.
apr 16 11:58:56 osmc bluealsa-aplay[1604]: /usr/bin/bluealsa-aplay: W: Couldn’t open PCM: Set HW params: Set format: Invalid argument: S16_LE
apr 16 11:58:57 osmc bluealsa-aplay[1604]: /usr/bin/bluealsa-aplay: W: Couldn’t open PCM: Set HW params: Set format: Invalid argument: S16_LE
apr 16 11:58:58 osmc bluealsa-aplay[1604]: /usr/bin/bluealsa-aplay: W: Couldn’t open PCM: Set HW params: Set format: Invalid argument: S16_LE
apr 16 11:58:59 osmc bluealsa-aplay[1604]: /usr/bin/bluealsa-aplay: W: Couldn’t open PCM: Set HW params: Set format: Invalid argument: S16_LE
Please post full logs…
reproduce the issue
