Does anyone know of a Bluetooth 5.2 (or higher) adapter that works with the Vero 4k+? I’m looking to convert a USB arcade joystick to wireless, but the module I found requires 5.2.
Thanks.
Thanks.
I don’t have a recommendation at hand unfortunately
Damn. Thanks, Sam. I’ll just have to keep searching to see if anyone knows any that work.
Can you get away with BT 5.0?
Maybe…maybe not.
When I posted, I had only found this one:
I found a few people recommending and using it. It has also been the only game in town for at least 5 years. (People speak about the owner and I couldn’t help but think of you and your own niche product in OSMC.) But, that one says it needs 5.2.
Today, I came across this one, which uses 2.1:
https://bit-trade-one.co.jp/en/usb2btplus/
Other than from Japan, I’ve only found them for sale on eBay and I don’t really trust the sellers. Also, I can’t find anyone who says they’ve bought and used one, so I’m quite hesitant.
Outside of these, I’ve found DIY projects, but I’m not looking to solder one together.
