Hi everyone,
I’ve killed audio on my Vero 4K and cannot attempt to play anything without seeing the “:(” of death.
A little knowledge is a dangerous thing.
I had read it was possible to output audio via bluetooth and though great let’s get that going with my headphones - a bit of reading and I happily I went and typed “sudo apt install a2dp-app-osmc” and accepted the 60 something additional packages it would need.
After a reboot the menu audio was complete distorted trash so I thought stuff even trying to work out how to pair a bluetooth device from here I’ll just uninstall if its going to do that. So I went “sudo apt remove a2dp-app-osmc” and it seemed to only want to uninstall a few of the packages it had supposedly needed to install and I thought who am I to question that.
After a reboot the menu audio is still stuffed and I still can’t play anything - really not looking forward to another clean install!
Is there something else I can do to troubleshoot - should I be reading anything sitting in /var/log/ ?
Edit:
Just realised I had stretch-devel main still in my sources.list so my issues could be related to that - reverting now.
