Hi Sam,
in the release noter of the october update you mentioned bluetooth support and provided a link to the testing thread for A2DP
After I upgraded to the newest official release I went to the app store in the hope to find this feature.
My problem: when I try to topen the App Store within MyOSMC nothing happens.
Does this mean that this feature is not yet in the App store
- Question: can wget http://paste.osmc.io/raw/qiyekuvafe -O- | sudo sh be applied on the vero or this only possible with the PI and BT Dongle?
Thanks and regards
Chris
