I’m trying to get the embedded Rpi3 Bluetooth running in order to stream audio. But I get stuck right from the beginning. (Btw, I saw some people using a bt dongle…. Why ? if it’s integrated already)
The following command is what I started with. Everything looks ok.
sudo apt-get install armv7-bluezalsa-osmc
But when I run this
bluetoothctl
I get a message that it’s waiting
Waiting to connect to bluetoothd…
And I cannot find anything in my bt available devices list, on my phone.
Thanks. Yes, definitely… I’ve been reading outdated posts, several to be honest and then once I realized, I tried to do some cleanup. I however thought that this first command was correct.
Reaching the limit of my knowledge. Maybe your flirtation with pulseaudio did something bad although I don’t understand why the bluetooth module isn’t loading automatically. Try reinstalling bluez and bluezalsa.
