Hello everyone,
Does anyone has the Bluetooth-HID based codes that would allow an unsupported Bluetooth device to connect to Raspberry Pi 3 and control Kodi?
Thanks!
Hello everyone,
Thanks!
I don’t have them, but I just wanted to add that I also want them to enable control from a Logitech harmony Elite remote. Thank you.
I am using my Harmony Hub to control OSMC just set it as a Windows PC, otherwise I used to set it as a PS3 when I had the PS3 IR adapter. It seems to keep loosing BT connection so it’s not that great
Thank you - that appears to have worked.
For future readers - to get the Pi & OSMC working with Harmony Hub via Bluetooth, I did the following:
