I’ve got a cheap bluetooth keyboard that works perfectly with osmc (except that I have to manually reconnect after every restart). it works flawlessly except for the fact that the keyboards also has a touchpad, that sadly doesn’t work. Can you suggest me a way to enable it or give me some hints to investigate the issue? Thank you.
Giuseppe
