Bluetooth Monitoring application (Part 2)
Related to this topic: Bluetooth monitoring
I want to install it on another Vero4K OSMC device. I’m trying the same as the last time but get stuck on this command:
sudo apt-get install -f libmosquitto-dev mosquitto mosquitto-clients libmosquitto1
osmc@osmc2:~/monitor$ sudo apt-get install -f libmosquitto-dev mosquitto mosquitto-clients libmosquitto1
Reading package lists... Done
Building dependency tree
 libmosquitto1 : Depends: libc6 (>= 2.28) but 2.24-11+deb9u4 is to be installed
 mosquitto : Depends: libc6 (>= 2.28) but 2.24-11+deb9u4 is to be installed
E: Unable to correct problems, you have held broken packages.
How and is it safe to install the latest libc6?
Or is the error related to the previous command I ran where I also got an error:
osmc@osmc2:~/monitor$ sudo apt-get update
Ign:1 http://ftp.debian.org/debian stretch InRelease
Hit:2 http://ftp.debian.org/debian stretch-updates InRelease
Hit:3 http://security.debian.org stretch/updates InRelease
Hit:4 http://ftp.debian.org/debian stretch Release
Hit:5 http://ftp.fau.de/osmc/osmc/apt stretch InRelease
Get:6 https://repo.mosquitto.org/debian buster InRelease [11.0 kB]
Get:8 https://repo.mosquitto.org/debian buster/main armhf Packages [15.8 kB]
Get:9 https://repo.mosquitto.org/debian buster/main all Packages [2132 B]
Fetched 28.9 kB in 2s (12.0 kB/s)
N: Skipping acquire of configured file 'main/binary-arm64/Packages' as repository 'https://repo.mosquitto.org/debian buster InRelease' doesn't support architecture 'arm64'
Or do I need to run this maybe first?
sudo apt-get upgrade -y
sudo apt-get dist-upgrade -y
Website from where I copied the commands: GitHub - andrewjfreyer/monitor: Distributed advertisement-based BTLE presence detection reported via mqtt
Any help would be appreciated!
Seems to be the wrong architecture.
You would want an armhf version, if available.
UPDATE: I think I got it.
I changed sudo wget http://repo.mosquitto.org/debian/mosquitto-buster.list
to be: sudo wget http://repo.mosquitto.org/debian/mosquitto-stretch.list
and now it installed!
Yeah I run into that the last time (2018) as well but I can’t remember and didn’t write down how I fixed that :frowning:
Actually I don’t think that’s the real issue.
It’s when I want to install mosquitto I get this:
So I need to know if and how I can update that on the OSMC.
