As the title already implies, I do have complications connecting a PS3 Gamepad to the RPi2 via Bluetooth.
First of, I followed this guide which worked fairly well, besides some compiling errors, in order to get rid of them I used a newer version of QtSixA from GitHub, which compiled flawlessly. After the installation of sixad I enabled Bluetooth via connman and now there’s only one thing left to do: Starting sixad. This turned out to be more difficult than I expected, since I’m basically stuck here.
osmc@osmc:~# sudo sixad -s
[ ok ] Starting bluetooth (via systemctl): bluetooth.service.
sixad-bin[2286]: started
sixad-bin[2286]: sixad started, press the PS button now
The Gamepad is simply not recognizing the bluetooth-device, or the other way around. To make sure both are working correctly, I did the same thing on a regular Ubuntu x86 machine and everything went fine. The activity led on the bluetooth dongle was actually flashing, which was not the case when attached to the RPi2, so I had a look at the hciconfig output:
user@vbox:~# sudo hciconfig
hci0: Type: BR/EDR Bus: USB
BD Address: XX:XX:XX:XX:XX:XX ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING PSCAN
RX bytes:6219510 acl:107254 sco:0 events:203 errors:0
TX bytes:7541 acl:114 sco:0 commands:74 errors:0
On the Raspberry Pi the output looks similar but the PSCAN status was missing, so I enabled it manually with the command “hciconfig hci0 pscan”. The dongle started flashing, but after starting sixad again, everything went back were it was, which probably means sixad is stopping the page scan. Just out of curiosity I opened a second terminal window, and started pscan again. Now the gamepad connects an is usable. In order to connect it, I have to go through these steps every single time, which makes it difficult to automate this process for example on startup.
If anybody knows a better workaround or any thoughts on this issue, feel free to share it.
Thanks in advance!
