Hi all
I was trying to pair my cell phone to the osmc but when I try to start the devices discovery from the interface it does not work and it permanently states as disabled, that is, I cannot discover any device
Any help would be appreciated?
Hi all
Sounds like the on board bluetooth may be disabled, logs would helps identify the issue:
Also you could try pairing from the Command Line :
Thanks Tom.
If you are pairing a phone for audio, you need to install the A2DP package first. Did you do this?
