BluRay.3D.FSBS
Hello,
I have a Vero V, and when i try to play a BluRay.3D.FSBS (codé en H265) film, it’s don’t work (my TV switch in 3D but i have half image and plenty of bluepoint..). Could someone tell me what to do ?
Thanks you
3D FSBS isn’t supported for HEVC at this time, only H264
ok thank you Sam. So i have to review it in 264 ? Do you know when it will be supported ?
3D H265 isn’t really a spec. It’s theoretically possible, but a lot of work and may not happen
ok, but there is a lot of Fsbs encoded in h265.. How to manage them ? I can read them correctly with my PC but not in Vero V …
See Full SBS Playback - #65 by Xeth84
@tanio99 has given some in depth explanations why this is a challenge in the past. It’s not impossible, but it is challenging.
Use ffmpeg to convert them to H264
Just to add my 2 cents: hevc is possible but needs a lot of work since we don’t have the documentation, it needs a lot of try & error. That’s why I will not look into it for the 4.9 kernel. But hevc FSBS support is on my list for the 5.x kernel.
Thank to all for yours answers.
in middletime i will use a converter to h264 as @fzinken et @sam_nazarko suggest…
@tanio99 : Super and when does the 5.x kernel will be available ?
There’s no ETA yet, it will take a while …
