I’m trying this out on a raspberry pi 2 and everything seems to work well except I’m unable to view movies that are straight rips of bluray disks. This works on my windows based kodi system. The log shows that the system is going to open the /BDMV/index.bdmv but it fails saying:
Unable to load libbluray.so.1, reason: libbluray.so.1: cannot open shared object file: No such file or directory
I would suggest since this OSMC distribution is supposed to be for Kodi based systems that this library be part of the distribution instead of leaving it up to the user to figure out. I don’t think my directory structure is that unique so I would suspect that others run into this (although they probably just try to do the apt-get install first…).
OSMC is still in alpha so there will be stuff missing, not working etc. The devs have said that the bluray library among other things will be included in the next release.
