Hello Guys,
I did an Update on my Vero4k. Via myOSMC Addon, but some time ago prior to that also in SSH session with apt-get update and apt-get dist-upgrade)
Now, my device is not booting into Kodi anymore. It’s stuck at sad face.
I already moved my Kodi-profile. It’s not the problem.
Already tried booting without attached HDMI or USB devices or LAN cable - not success.
I’ve uploaded my logs: https://paste.osmc.tv/edomawuxag
Seems like there’s something wrong with libcec?!
Any help would be highly appreciated
Thanks in advance.
Your apt sources.list includes buster-devel which is currently under repair. I think you will have to re-install from the latest image.
Copy your .kodi directory out first to an external disk so you can restore your settings.
What does “under repair” mean?
so should i edit the sources.list ? i dunno what buster-devel means, i can remember that i added it a long time ago (i guess for a beta or something) might be…
i already moved my .kodi Folder to ~/kodi.bak
The staging repository is for v19 testing. It is a work in progress.
Ok.
I removed the buster-devel from sources.list.
How do i install the current version of kodi now? which command ?
Move your .kodi folder to external media - reinstallation will wipe the device.
Then see Reinstalling OSMC - Vero 4K - OSMC
Have a look here: SadfaceBootloop - #9 by Strampi5
The trouble is, you’re also now on the development kernel, so a reinstall might be the preferable solution.
Thanks everyone.
I reinstalled OSMC and set it up as a new device (long overdue :D).
Good luck with v19, looking forward to it!
Have a nice weekend.
