I’m currently running Armbian on the Vero 4k+, booting it from the SD Card using the toothpick method.
Are there any ways I could default the boot process to the SD Card instead of the emmc? I don’t want to mess with emmc and would like to avoid using the toothpick everytime I need to reboot the box.
If you have a dtb and kernel on the SD card the OSMC bootloader will normally boot from those without a toothpick. Does the armbian install mess with the boot parameters (eg with a aml autoscript on the SD card)?
I did attempt Armbian on Vero4k a while back but didn’t get very far. Is it easy?
@pauloagt@grahamh
Hi, I’ve bought a new Vero V, and was thinking of repurposing my existing 4k+ as a simple homeserver and installing Armbian. A few questions if I may:
(i) In general how well does Armbian run on the 4k+ (with 2gb ram)?
(ii) Would you know if there’s a real risk of bricking it if installing on the emmc? And would it be possible to reinstall the firmware (as indicated in the link)
