So today i press yes to update my OSMC on Raspberry 3+b but got bootloop (sad face) after it. i tried a couple of solutions i’ve found on the forum but with no success
Log:
https://paste.osmc.tv/etofeweqoj
Log:
Both times the weather plugin seems to be unable to load a file (png file).
Try disabling the plugins if you can. Dunno how to do that on the CLI though.
thanks, but i’m stuck with SSH and have no idea how to disable them. Thanks anyway!
Yep. But it is not a boot-loop. It is kodi that is starting over and over.
let’s see of the others in this forum have more insight
Looks like you’re running Leia (v.18). I recommend you downgrade to .345, since the latest two nightly of Leia got issues and is being worked on.
Downgrade instructions is on the first post on Leia test thread
This solution worked for me.
Ok, i finally figured it out. My (last) problem was that i was trying to downgrade via SSH.
Connected the keyboard and downgraded and everything sorted out.
Thanks @joakim_s
