Hello,
I made upgrade from terminal to Debian 9
After that i had : sudo apt-get dist-upgrade -f
Extracting templates from packages: 100%
Preconfiguring packages …
(Reading database … 44347 files and directories currently installed.)
Removing rbp2-device-osmc (1.4.4) …
WARNING: You have tried to remove a package that is essential to OSMC’s operation.
To undo these changes, run ‘sudo apt-get -f install’.
dpkg: error processing package rbp2-device-osmc (–remove):
subprocess installed pre-removal script returned error exit status 1
rbp2-device-osmc
Job for samba.service failed because the control process exited with error code.
See “systemctl status samba.service” and “journalctl -xe” for details.
https://paste.osmc.tv/zeqipomahu
I am trying to install PiHole & PiVPN
Also
➜ osmc service nmbd status
- nmbd.service - LSB: start Samba NetBIOS nameserver (nmbd)
Loaded: loaded (/etc/init.d/nmbd; generated; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2017-11-19 20:05:39 EET; 10min ago
Docs: man:systemd-sysv-generator(8)
Process: 4873 ExecStart=/etc/init.d/nmbd start (code=exited, status=1/FAILURE)
Nov 19 20:05:38 r3 systemd[1]: Starting LSB: start Samba NetBIOS nameserver (nmbd)…
Nov 19 20:05:39 r3 nmbd[4873]: Segmentation fault
Nov 19 20:05:39 r3 nmbd[4873]: Starting NetBIOS name server: nmbdSegmentation fault
Nov 19 20:05:39 r3 nmbd[4873]: failed!
Nov 19 20:05:39 r3 systemd[1]: nmbd.service: Control process exited, code=exited status=1
Nov 19 20:05:39 r3 systemd[1]: Failed to start LSB: start Samba NetBIOS nameserver (nmbd).
Nov 19 20:05:39 r3 systemd[1]: nmbd.service: Unit entered failed state.
Nov 19 20:05:39 r3 systemd[1]: nmbd.service: Failed with result ‘exit-code’.
➜ osmc
