I brought the raspberry pi starter kit from the OSMC website, however after installing OSMC I am unable to activate the wifi dongle. i.e. it doesnt show up in the network settings.
The Dongle was shipped out by the guys as OSMC so I assume it should work.
Sorry I was just referring to the fact that first time you load up the pi with the sd card it installs the operating system. After the first boot it automatically takes you to osmc.
I have been playing around in terminal and the wifi dongle shows up when i use the dmsg command.
However when I try
osmc@osmc:~$ connmanctl
connmanctl> enable wifi
I get the line
error wifi: method “SetProperty” with signature “sv” on interface “net.connman.Technology” doesn’t exist
Occasionally we change the chipset in the WiFi dongle. My guess would be that the version that came preloaded is out of date (we image them with the previous month’s update so if anything is wrong we have time correct the issue). If you give me the order number I can probably confirm that for you.
There are two ways to remedy this:
You can go to Download - OSMC and choose the latest image. This will involve re-loading the SD card.
Alternatively, if you’re able to, attach an Ethernet cable temporarily to the Pi, go to My OSMC → Updater. Check for updates and let the system upgrade.
Then shutdown your device (select Power → Shut down) and unplug it. Remove the Ethernet cable and turn the Pi on again.
You should now have more joy in My OSMC → Network Settings
I see the issue here. Thanks for the dmesg. That was quite helpful.
The issue was caused by the fact the firmware for the wireless adapter is missing. I have added the firmware and pushed it out as an immediate update. If you connect the Ethernet cable once more (I do apologise for this), and upgrade again, you should hopefully be able to use your WiFi stick.
In the next update, support for the dongle will be included in the disk image directly
The dpkg -l | grep refers to a pipe. This is next to the shift key for me.
The firmware file should be case-sensitive, so if you update again now for a final time it should be fixed! If not, I’ll grab a dongle in the morning and have a closer look
So, I have reinstalled osmc from the end of August build on my rpi 2 and performed an update. I am still having some issues with the MT7601 wifi dongle. Grateful if someone could help with that. Below are link to log extract that can help with the debugging:
