Yes, I can pair OSMC → Samsung TV. In this instance the TV automatically enters the (useless) ambient mode and assumes that OSMC will be the source of audio, so the TV will act as a speaker. I can’t skip this mode, so no luck there.
aplay -L output (while connected to the TV):
osmc@osmc:~$ sudo aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
bluealsa
Bluetooth Audio Hub
btaudio
Bluetooth Audio
hw:CARD=sndrpihifiberry,DEV=0
snd_rpi_hifiberry_dacplus, HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0
Direct hardware device without any conversions
plughw:CARD=sndrpihifiberry,DEV=0
Hardware device with all software conversions
default:CARD=sndrpihifiberry
Default Audio Device
sysdefault:CARD=sndrpihifiberry
dmix:CARD=sndrpihifiberry,DEV=0
Direct sample mixing device
hw:CARD=vc4hdmi0,DEV=0
vc4-hdmi-0, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi0,DEV=0
default:CARD=vc4hdmi0
sysdefault:CARD=vc4hdmi0
hdmi:CARD=vc4hdmi0,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi0,DEV=0
hw:CARD=vc4hdmi1,DEV=0
vc4-hdmi-1, MAI PCM i2s-hifi-0
plughw:CARD=vc4hdmi1,DEV=0
default:CARD=vc4hdmi1
sysdefault:CARD=vc4hdmi1
hdmi:CARD=vc4hdmi1,DEV=0
HDMI Audio Output
dmix:CARD=vc4hdmi1,DEV=0
cat /lib/systemd/system/bluealsa-aplay.service output (should be as default, since I haven’t changed the contents):
osmc@osmc:~$ cat /lib/systemd/system/bluealsa-aplay.service
[Unit]
Description=A2DP Playback
After=bluealsa.service syslog.service
Requires=bluealsa.service
StopWhenUnneeded=true
[Service]
ExecStartPre=/bin/sleep 3
ExecStart=/usr/bin/bluealsa-aplay --profile-a2dp 00:00:00:00:00:00
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=A2DP-Playback
Restart=on-failure
[Install]
WantedBy=bluetooth.target
