BT remote RT-MWK02+ on RP1 B+ not working
Since I have OSMC I don’t get my bluetooth remote (RiiTek RT-MWK02+) working.
so my question is, how to get this bluetooth controller working?
can I try the many tutorial for raspbmc, or do I need to install some drivers?
I had it working on raspbmc before.
an I can find it with lsusb: Screenshot by Lightshot
I hope you can help me and tell me what to install, or link me to a tutorial :smile:
link to my bt keyboard: http://www.dx.com/nl/p/rii-rt-mwk02-mini-wireless-bluetooth-keyboard-w-touchpad-laser-pointer-backlight-black-167607
is hci0 up and running ?
type to check:
sudo hciconfig
thank you for your reply,
hci0 was down, but when I try to get it up I get this error:
Operation not possible due to RF-kill (132) (Screenshot by Lightshot)
So right now I’m install rfkill and follow these steps: Enabling bluetooth
thats what i did too for my wiimotes :slight_smile: then just add a little startup script and put it in cron or something then your good to go
thank you @Toast it’s now working 100%.
I didn’t saw the “network” option in “My OSMC” but it works perfect to add wifi/bluetooth devices.
even after a reboot my remote is still connected. (no script needed, just pair and connect once)
Are you both running the latest updates ?
The problem of Bluetooth not loading automatically on startup was fixed recently, if you are still having problems with this, please post a debug log demonstrating the problem.
havent looked at the bluetooth settings still using my script since it does exactly what i want should however adapt it to current osmc settings
